Help please,I need the 2005 Hyundai Sonata radio/cd player code and how to set it
Help please,I need the 2005 Hyundai Sonata radio/cd player code and how to set it my battery went dead and cit has not worked since. I also need to know how to reset key-less entry. Finally my clock display is out. :confused:
I found my answer. If this question comes up again, I suggest you may want to check the 2nd row of fuses from the bottom on the far right hand side 10 amp fuse labeled d/clock on the fuse box below the steering wheel. It fixed all 3 problems. I did not have to code anything.
| All times are GMT -5. The time now is 08:26 AM. |
