Helppppp please
ok so got a error code P0087 says low fuel rail pressure so I changed the pump in the back of the seats lights still on saying the same code bought a regulator can't find it on the car is it on the pump or the fuel line anybody have this code before and if so what's the fix?
Originally Posted by Chris Williams
(Post 53375)
First thing I would do is write the code down then proceed to erase it
Wait to see if it comes back. If it doesn't come back then ignore it If it does come back then go about check for fuel pressure Does it match the diagnostic trouble code? If not then sensor is faulty If it is then would check fuel pump or regulator Also check to see if fuel relay is working properly Good luck |
