Howling engine
Im driving a 2004 Sonata (gold)
After 1 year of comfort driving the 4 cylinder , 16 valve enging starts to give a funny sound. The engine gives out a "howling" sound. It happens only after the car is parked for about 2 to 3 hours and when you start the engine and drove with a speed of about 25 kph with 1st and 2nd gear. Kindly advise Thanks |
RE: Howling engine
Listen for the noise from the timing belt area. Those vehicles were bad about the timing belts coming apart.
RE: Howling engine
If your noise is only occurring when you are on the move, it could be a worn brake pad, as these have sensors in them which give off a high pitched squeel, instead of having a warning light on the dash.
RE: Howling engine
i've had the same issues with my 95 sonata it is the belt tentioning arm that needs replacing :D good luck
