Hyundai Sonata 2010 A/C Control Valve
Hi there!
I'm having a challenge on A/C compressor's control valve. I bought a new compressor however, only the control valve is not working, the control valve has a fire but, it's very low and the A/C is still not working. Can control valve be repaired or should i buy a new one...? |
Common A/C Problems:
A/C Blowing Warm Air No pressure or low refrigerant levels in the A/C System Compressor Clutch Freon R134a leaks A/C compressor not engaging. Liquid lock of the compressor A/C blowing hot air Compressors switches on then off very quickly. I just bought Hyundai Sonata 2010 A/C Compressor cost 190$, everything goes well. I think control valve is not the big problem for your A/C. Try to exchange a new one. |
