Installing Daytime Running Lights in Sonata 2005
I love my Sonata 2005 and I will be importing it from US to Canada soon. One of the Canadian requirements is to have a functioning Daytime Running Lights (DRL) on them. Unfortunately my car does not have DRL at all and so I want to install them. I wonder whether this is possible to do? The Hyundai dealership denied my request saying that the car is too old, but a local mechanic mentioned that he might be able to do it. So I have the following questions:
1. Is it possible to add DRLs on Sonata 2005?
2. What would be the overall procedure? I read this: https://www.hyundaiforum.com/forum/h...perience-6429/. It says that DRL will be wired to high beams at half power. It also says that the parking lights can be wired up as DRLs too. So which option is best?
3. Is it safe to do such modification? I wonder whether adding DRLs will overload the fuse box or create some other heating issue, etc?
Hope to find some help here.
Best,
John
Best,
John
Many places to buy DRLs
Here is one on youtube
Here is a video on how to install DRLs
You can also turn on your own lights by adding a couple of relays to turn on whenever the key is in the on position.
Good luck
Good luck
As I said, it is possible to add relays to turn on your own lights whenever you turn the key to the on position
You just have to know how. Auto electrician can do it.
Or if adding these DRLs are legal enough for your locale then the modules should be plug and play.
The modules should only want a power source and ground in order to work
The power source should be controlled by the key.
Yes, I have front fog lights. But the post here (https://www.hyundaiforum.com/forum/h...perience-6429/) says that fog lights cannot be used as DRLs. So I thought of not doing that.
I called CanadaTire (which will eventually do the federal inspection in Canada) to confirm that I can directly use my fog lights as DRLs.
This is great since now I only have to add a relay and do some wiring.
Thanks for the help @avisitor and @NovaResource!
