Location of ECT sensor on 2000 Sonata
Old Jul 15, 2011 | 08:30 PM
anduneg's Avatar
Default Location of ECT sensor on 2000 Sonata
I have tried researching for the location of the ECT sensor, but no luck. Anyone out there knows where it is located on a 4 cyl. engine? I got the part, but cannot seem to find it! Any help will be appreciated!
Old Jul 16, 2011 | 01:00 PM
It's In the cylinder head:
Old Jul 17, 2011 | 03:28 PM
anduneg's Avatar
I appreciate the help! One question, where did you get the diagram from? Seems like it is impossible to get anything on a Sonata without having to buy a software or book. Thanks again!
Old Jul 17, 2011 | 07:28 PM
Hyundai Service Website
Sign up for free access
Old Jul 19, 2011 | 05:44 AM
Iris Mark's Avatar
First off, just to clarify: your car's engine is referred to as an "in-line" four, or I4, as the cylinders are lined up in a row, rather than in two banks of 3 (V6) or 4 (V8). I don't want to sound like I'm nitpicking - that's how it is. 8D
Anyhow, according to Webtech www.hmaservice.com/webtech:
P0171 means the fuel system is running lean, which could well point to the MAP sensor (your car has one of these in place of a MAFS).
P1610 refers to a "CAN BUS OFF ERROR".
Exact text from Webtech:
DTC No. C1610 CAN bus off error [repair]
Inspect CAN bus wiring
Check the connectors C34 or C104, C94-4, C93-3
Probable cause
CAN bus cable open or short to ground or battery
I can't find P1101 on Webtech, but 1100, 1102 and 1103 refer to the MAP sensor.
I hope this helps!
chastsmith
Feb 18, 2019 08:52 PM
jazkat74
Nov 27, 2013 04:41 PM
kevin95835
Aug 27, 2011 12:12 AM
skeefe731
Mar 10, 2010 09:20 PM
