Misfire cyl. 3
#11
And why exactly does your mechanic think it is not the cats?
These codes mean: Warm-Up Catalyst Efficiency Below Threshold.
Threshold is 95% efficiency. If they are only 94% efficient they should throw you a code. I know how old your car is but how many miles?
Some people had luck using a lacquer thinner treatment to bring it back up over the threshold. It's temporary at best.
Related videos:
https://www.youtube.com/watch?v=5icTmYItwiE
https://www.youtube.com/watch?v=qJTmddbOxMk
Related videos:
#13
update. Mechanic hooked up his code reader and it' showing the voltages for all 4 O2 sensors are jumping around not staying steady.
#14
I am not a mechanic and I don't have a lot of experience with code reading. Many mechanics focus too much on codes and forget some basic things in the process. One thing I would do is disconnect the computer and check for any corrosion on the pins and then I would go through all other harnesses and connections and inspect them. Sometimes disconnecting and reconnecting removes enough corrosion to fix a voltage drop. A sketchy ground connection could also cause an intermittent contact. Inspect the wires, blow compressed air on the outside of the sensors. They need good airflow around them. Check for minor exhaust leaks etc.
I have even heard of cars where an radio frequency interferes with the computer and causes misfires. I am not trying to scare you, just make sure the very basics are taken care of before throwing expensive parts on the issue.
Good luck. I am afraid I can't help you any further. Nonetheless, please update when you have fresh info.
#15
This is crazy
#16
So, what now?
Did you change the coil packs that were arcing?
Was it that which was causing the misfires?
The other thing which I was wondering is ... Does your car have a MAF or MAP sensor?
Can you clean it out with MAF sensor cleaner?
The thinking is that maybe it is calling for more fuel than necessary
And therefore causing the cat codes or O2 codes???
Long shot.
Long shot.
#17
First order of business is to replace all coils on Plugs with Denso units. Denso is the original supplier. Sure it is expensive but it is necessary. The misfires send unburnt fuel into the catalytic converter where it burns off. The resulting heat can melt the core of the converter. At that point it becomes REALLY expensive.
If you must save money find used DENSO COPs in a junk yard.
Your Buick episode goes back many years and has no direct bearing on this situation. Of course it is possible that something similar happens. It is just not likely. On the other hand the Autozone parts are highly suspect.
Snab_Nacl
10-04-2011 03:06 PM
