Need an extra alarm remote for an '06 Sonata
Does anyone have any advice or experience other than from the dealer? Is it hard to program to the car? thanks
To program the remote, you "WILL" need to see the dealer,,, they will install GDS and do the programing.. be sure to provide both remotes if availabe, as both need to be entered at same time when in the learn mode.
What is GDS?
sbr711 can you do that yourself from Hyundai Service Website ?
Originally Posted by Flotsam
(Post 37258)
(Post 37265)
What is GDS?
Computer with GDS program installed, plug into DLC with VCI (Vehicle Communication Interface), then go about the business needed for what you is doing,, pulling codes from modules, clearing codes, reprograming SRS, PCM, TCM, BCM, ABS/ESC, monitor data where ever, actuation test,, all kinds of fun stuff I can do. I gots the discs sitting here to load the Software on the home computer, I'll copy it and install on my own laptop if I ever get 1.. We have laptop froom Hyundai as SST (Panasonic Toughbook),, a PC in my stall that will cover 3 stalls with the cord, and laptop floating arounf the shop... have it installed on another PC, but manager too stingy for getting a simple USB extension cord to cover the couple stalls there.. |
(Post 37269)
If you don't want to go to the dealer then you need to buy a $2000+ computer scanner from Hyundai to do it yourself, or go to someone that already owns the Hyundai comuter scanner. Also, you can only program a max of 2 remotes.
I do suppose that this connects up through the ODBII connector right? What do independent (non-Hyundai) garages do? They can't do certain things on a Hyundai? |
