-   -   Need to see a diagram of the firing order (https://www.hyundaiforum.com/forum/hyundai-sonata-19/need-see-diagram-firing-order-7525/)
wardf Oct 30, 2009 03:13 PM
I had/have the P0301 error. Which to my understanding is a misfire in the #1 cylinder. This is an 02 Sonata. I changed plugs and wires in june of 08 so I thought it couldn't be that. I checked the coils and they read OK, next the fuel injector and it ohmed out good also. I really didn't want to pull the intake again but I did and the #1 plug looked dark. I went to Autozone and got another set of Bocsh wires and he told me the original set of plugs i got would not work which were bocsh platinum plus. He said they couldn't handle the voltage. He told me I needed the plus 2s or the plus 4s so I bought the plus 4s. I took the wires off all at once because I had to trade them in to get new ones. When I put it all back together it is worse than it ever was and I think that maybe I mixed the wires. On the coil pack starting at the front of the car I go 1-4-2-5-3-6 and I know for sure which cylinder is #1, the right side closest to the firewall, I need to know the other 5. I thought it went 1-2-3 across the backside next to the firewall and 4-5-6 on the radiator side of the engine. Anyone know for sure? Thank you in advance.
wardf Oct 30, 2009 06:12 PM
Googled it and found it but thanks anyways. And this did take care of everything, running like a top:D
