OEM 17" tire pressure?
Just put OEM 17" rims and tires on my previously 16" equiped 06 Sonata. My door tag only gives PSI for 16". Can someone please tell me what the 17" door tag pressure reads?
225/50/17 Thanks in advance for your reply.. Sheri |
1 Attachment(s)
Thanks but its on the sidewall 35...hmm
The pressure on the sidewall is not what the tire pressure is supposed to be. Read the owners manual.
Read and learn: Car Talk Tire Safety, Brochure (DOT HS 809 361 October 2001) Tire Tech Information - Sidewall Markings |
(Post 39600)
Read and learn: Car Talk Tire Safety, Brochure (DOT HS 809 361 October 2001) Tire Tech Information - Sidewall Markings Again thanks for the info., we won't be following it though. |
Originally Posted by Myferrari
(Post 39608)
You read my post wrong. The max. pressure on the tire sidewall reads 50psi. There is 35psi in the tires now and the sidewall is just about on the ground, a hard corner and it's toast. I don't see how anyone is running 30psi and not encountering problems, or maybe there are. Under running the max pressure by 20psi (especially on a lo-pro) is a new one one me.
30 PSI is the correct amount for the 17" tires on the Sonata. Thousands of Sonata have been driving for hundreds of thousands of miles with no problem.
(Post 39608)
Speaking from experience of building engines on garage floors with hand tools.
(Post 39608)
| All times are GMT -5. The time now is 09:49 AM. |
