Power Steering Pump replacement on 2004 Sonata V6
The pulley on my power steering pump is wobbling. It is making a squealing noise as well. So I guess I have to replace the whole pump. Can anyone give me a step by step on how to replace this or recommend a book that I can purchase that tells me how to do it?
RE: Power Steering Pump replacement on 2004 Sonata V6
I tried to post the actual directions but the board won't let me for some reason. So you'll have to go here and read them for yourslef. Sign up for free access.
http://www.hmaservice.com/ |
1. Remove the pressure hose from the oil pump.
NOTE: When assembling, us e a new O-ring. http://www.hmaservice.com/data/Passe...G/epa9016a.gif 2. Disconnect the suction hose from the suction connector and drain the fluid into a container. CAUTION: When removing the suction hose, cover the generator with vinyl not to be damaged by the fluid. http://www.hmaservice.com/data/Passe...G/epa9016e.gif 3. Remove the V-belt. (V-6 ENG.) http://www.hmaservice.com/data/Passe...G/epa9004a.gif 4. Loosen the tensioner adjusting bolt to remove the V-belt (DOHC ENG). 5. Remove the oil pump mounting bolts and disconnect the pressure switch connector. http://www.hmaservice.com/data/Passe...G/epa9016c.gif |
INSTALLATION
1. Install the oil pump to the oil pump bracket. 2. Install the suction hose. 3. Install the ribbed V-belt and adjust its tension. |
4. Connec t the pressure hose to the oil pump, and the suction hose to the oil reservoir.
NOTE: Install the hoses so that they are not twisted and they do not come in contact with any other parts. 5. Replenish the reservoir. Recommended fluid : Power steering fluid (PSF-3) 6. Bleed the system. 7. Check the oil pump pressure. 8. Install parts by referring to the torque specification. |
