Radio has no power, all other electrical fine
I have a 2007 Sonata. The radio has no power. This happened after a bad battery boost (reversed polarity)
I swapped the radio with another one. It's possible both radios are dead, but I think the problem is something else. I've checked the fuses in the fuse-box that's in the dash, they seem okay. Is there something I am missing? |
Take a DVOM and check the power at the connector to see if there is 12 volts
!2 volts should be at the keep alive for memory And 12 volts should be there when key is turned to "on" or "acc" Check the ground to make sure there is a complete path/circuit for the radio to work Good luck |
2012 sonata
same issue here what can I do trying to avoid paying 300 for another factory radio |
Did you check all the fuses?
Check for voltage at the power to the radio Both the keep alive memory wire and ignition power If you need a new radio then you can always put in an after market radio?? On my 2001 Elantra, I bought a cheap radio for 30 dollars and put it in myself. |
