replacing fog light bulbs
can anyone tell me me the easiest way to get at, then change a fog light bulb on a 2009 sonata. thanks
I do them on a rack.. reach up inside and replace bulb...
As a DIY, you'll have to improvise. May have to undo plastic under panel to see in behind lamp, not a big deal,, should be called out in owner manual I think. |
thanks sbr, at a quick glance and a diyer i was wondering how you get at the thing and what must be taken off. But from what you say the key is from the bottom of the car and def. must remove some plastic body parts?
