santa fe wheels
Old Nov 16, 2010 | 06:15 PM
06nf's Avatar
Default santa fe wheels
does anybody know if the 18" wheels for a 2010 santa fe fit on a 2006 sonata? i know the bolt pattern is the same and that i would need low profile tires but my main concern is the offset since ill be lowering the car. i have a friend that has 18'' genesis coupe wheels on his sonata and without lowering the car when taking a hard corner or with a full car the rear tires rub. but those wheels are meant for a rear wheel drive car and the rear ones are wider. any comments or experiences. thanks
Old Nov 17, 2010 | 08:13 AM
rallyman's Avatar
I don't have any personal experience with your situation but I have seen a Sonata with the 18" Veracruz wheels on it. I don't recall if it was lowered or not. I'm inclined to think that the Santa Fe wheels are not much different in offset than the Sonata wheels.
Old Dec 12, 2010 | 04:14 PM
Allan R's Avatar
Don't know what wheels you have right now. Here's something for you though. I have an 07 Sonata Limited with the 5 spoke 17" alloy wheels. I got a set of Azera 17 alloys for my winter tires (using the same tire specs as summer ones). The Azera wheels are a perfect fit.
Going to an 18" may have the same bolt pattern but they are not designed for your Sonata. This would be a good question to put to a dealer or a tire shop. Curious to know what you find out. Personally, I like the look of the 17s, I think the 18's would probably look good too, but like you said, they need to be functional.
Old Dec 16, 2010 | 05:19 PM
06nf's Avatar
well i ended up getting 19" genesis coupe wheels for a steal. i lowered the car on h&r and these wheels fit perfectly. the only thing is that you have to use 235 35 19 tires for the front and rear other than that they look great. thanks for your comments
Old Dec 16, 2010 | 07:57 PM
Be sure to post pics!
Wisconsin-Autocrosser
Nov 18, 2010 09:51 PM
oem_motorsports
Apr 30, 2008 12:37 AM
perry
Dec 7, 2005 03:17 PM
djs1967
Sep 19, 2005 11:35 AM
socaltib
Aug 5, 2005 02:59 PM
