Sonata 2006 Starter issues
Greetings:
my car just clicks when i turn it over. It's been suggested that there is a short in the starter (and if i give it a nudge, it might start) to at least get it to the dealer. Can someone tell me where the starter is on this pig and what it looks like? Cheers Carloochey |
What engine? 2.4L or 3.3L? It should be on the side of the engine that faces the radiator. Follow the positive battery cable to the starter.
Tapping a starter with a hammer will allow it to start if the starter is starting to go. However, if you don't know what a starter looks like, I'd suggest letting someone that knows do it. |
3.3. I actually followed the battery cable to the engine and there was a rubber plunger thing (yes, I'm very technical). It wasn't seated properly, so i pushed it in. It now works like a champ and I can at least drive it to the dealer..
Thanks for the quick reply. |
If it was loose, that was probably your problem and won't need a trip to the dealer.
| All times are GMT -5. The time now is 05:35 AM. |
