Sonata CV joint problem
Hello!
On my Hyundai Sonata I got a problem with the right (passenger side) cv joint - it is making a clacking noise around the front right wheel. I come from Europe. Original halfshaft for the Sonata costs here 520€!! (CV joint is not sold separately) On ebay USA I find complete new halfshaft with the postage to Europe for $150!! Here the problem occurs. VIN numbers of American and European hyundai cars can not be compared. Will the halfshaft for american car fit my european Sonata? Tech spec for my car: European 1999 Sonata 2.5 V6 161 bhp, with ABS and TCS. Manual gearbox! Tech spec for USA halshaft on ebay: [/align] Make Model Year Group Description Application HYUNDAI SONATA 1999 TO 2005 FITS FRONT RIGHT (PASSENGER SIDE) CV AXLE DRIVE SHAFT 2.5, 2.7 V6 So I ask you, are halfshfts the same for the manual and automatic transmission? And if the USA driveshaft fits on European car? Thanks for the answer! |
RE: Sonata CV joint problem
So I ask you, are halfshfts the same for the manual and automatic transmission? [IMG]local://upfiles/4972/6B883CBA26314524BAF2B7E20CB4894A.gif[/IMG] Also, U.S. cars apparently can have one of two different CV joints, DOJ and TJ types. Looks like the TJ type has a harmonic balencer installed on the shaft, where DOJ types do not. [IMG]local://upfiles/4972/ACE1C7C2B6F04A37A25EDFE2A74AFC91.gif[/IMG] [IMG]local://upfiles/4972/4FBF47957A424E65AD529F6BA60FBEA8.gif[/IMG] And if the USA driveshaft fits on European car? I hope what I've shared helps. |
NAPA Online (another major auto part supplier in the U.S.) shows the same part number on the manual with ABS as the automatic with or without ABS. Only the manual without ABS is different. Price (with core charge) is about the same as the $150 for the Ebay item. None of this helps determine if the U.S. part is the same as the European.
Thank you for answers and the NAPA website. Unfortunately, NAPA will not send things in Europe.
Here is the driveshaft that I have looked at ebay: http://cgi.ebay.com/ebaymotors/ws/eB...m=150279239844 The price is great, and they shipped this item in Europe... What is your opinion? |
What is your opinion? Good luck. |
