speed sensor change
sonata 1998. The speedmeter doesn't work and want to know how to replace the speed sensor's behind the cluster. Or am I wrong?
How many speed sensor are there in this car? Thanks |
RE: speed sensor change
sonata 1998. The speedmeter doesn't work and want to know how to replace the speed sensor's behind the cluster. Or am I wrong? How many speed sensor are there in this car? http://www.hmaservice.com/files/331/...4/0240022A.gif Here are the diagnostics for the 1998 Sonata sensor with a multimeter (from http://www.hmaservice.com/). VEHICLE SPEED SENSOR[/align] 1. Disconnect the speed sensor connect and remove the speed sensor.[/align] 2. Connect the positive(+) lead from battery to terminal 2 and the negative(-) lead to terminal 3.[/align] 3. Connect the positive(+) lead from tester to terminal 1 and negative(-) lead to terminal 3.[/align] http://www.hmaservice.com/data/Passe...G/Y90-016A.gif 4. Turn the speed meter shaft using a flat driver.[/align] 5. Check if there is voltage change from about 0V to 11 V or more between terminal 1 and 3.[/align] 6. The voltage change should be 4 times per each revolution of the shaft.[/align] http://www.hmaservice.com/data/Passe...G/Y90-016B.gif |
If I change the speed sensor allready, but, the speedmeter still doesn't work, what the problem can be? |
| All times are GMT -5. The time now is 05:35 AM. |
