squeaky front end drivers side
Old Feb 10, 2022 | 09:47 PM
B Roush's Avatar
Default squeaky front end drivers side
I have a sqeak in front end on drivers side of 2008 Sonata. The shop diagnosed and replaced the upper control arm with bearing assembly. Didn't help.Any ideas? Thanks
Old Feb 11, 2022 | 05:31 PM
Sometime we can do this.
If you get the squeak when the front goes up and down, have someone bounce the vehicle while you attempt to pin down where it is originating.
Depending on where it is , sometimes a little rubber lubricant will help if sprayed in the correct spot.
If you can't pin it down , then you might want to have a different shop check it out.
JPaulV
Jul 9, 2017 02:35 AM
MichaelBraud
Jul 12, 2012 12:47 AM
bernd
Mar 12, 2009 10:35 AM
sparxx
Mar 26, 2007 11:32 PM
kittbailey
Dec 27, 2005 11:13 AM
