starting issue
Old Sep 22, 2013 | 11:22 PM
gobama_88's Avatar
Default starting issue
ok so 1st car is 05 sonata 2.4l manual when i just replaced the lower block of this engine and went to start ran fine but the crank shaft position sensor was rubbing against the crankshaft outer ring so tried to adjust sensor no joy still rubbed then while engine was operating then while operating the motor cut off and now when i turn starter over the timing belt components wont turn but stater still motors along wondering if the senor tells the starter to engage to the flywheel if so i know my problem would be the position sensor.
Old Sep 23, 2013 | 12:11 AM
gobama_88's Avatar
i meant the cam shaft position sensor
rosie
Aug 26, 2020 03:33 PM
squirel022003
Mar 13, 2008 01:15 AM
Kellen128
Feb 8, 2008 09:32 PM
rdhussey
Aug 22, 2006 10:41 PM
anawanahuanana
Dec 14, 2005 03:16 AM
