Trunk problem
2005 Sonata.Need advice concering trunk problem.When I use trunk opener on key holder or button in the door there is a clicking noise but the trunk will not open.Any advice.Of course this is out of warrenty. Thanks, Rick
RE: Trunk problem
You just need a slight adjustment of the catch and latch. Maybe a little grease will work. Or it could be the trunk is not popping up because it's sticking to the weatherstrip rubber or the spring is unsprung. Isn't your car under warranty?
