Warranty/oil change interval
Have been driving my '09 for almost 3 months now and am reaching 5000. The maintenance calendar recommends oil change & filters etc. at 7500 as do most folks. bUt at the bottom of the maintenance calendar there seems to be the old fashioned recommended oil every 3k/3mo. so have i voided my warranty already or what?
I'll assume you have the 3.3L V6 engine, which oddly recommends oil changes at 7500. However, if you read under the "severe service" specifications, you'll notice it says the cars driven on "salted" roads qualify as "severe service", which is just about most of the cars in the US. Therefore, if they want to be stinkers about it, yes you voided the warranty.
I can't bring up the 2009 Owner's manual from hmaservice, or I could give you a better answer, basically the maintainance schedule is all there. Read it carefully. The way around you problem is this: Warranty is still valid if you do the work yourself, or you go to another shop at the specified schedule. All you have to do is keep a "log" and document the service performed. So make yourself a "log" and fill in the pertinent information. Mind you, the 3.3 has a non conforming oil filter with two "o" rings, so it's not a thing you take to Jiffy lube. |
Sorry. I have a 4 cylinder w/ automatic. This is based on what I saw logging in to the hyundai owners site which doesnt seem super reliable.
The 2.4 is a 3k oil change interval. But like I said, chances are your car is "severe service" anyhow.
It says 7500 in the manual, or 3000 with severe service.
I'm curious about that salted road thing though. Pretty much none of the other things apply. This is a commuter car, it spends 90% of the time on the highway going 65-70. In south florida winter. (70 F outside) |
Originally Posted by maestronole
(Post 19561)
Well, of course in S. Florida, there is no salt on the roads. So I guess you ok. Just follow the specs.
