V6 Terracan misfire with injector fault
Hi all, I have 2004 petrol Terracan. I had an inlet manifold leak when I purchased the vehicle which I rectified but now I seem to have a fuel injector issue. I have replace all 6 fuel injectors, replace all the injector connections. It's hard new leads, plugs and coils and a fluid service. I have tried testing at the PCM but all the wiring diagrams I can find do not accurately represent at my PCM. Has anyone had an injector previously on the V6 and how did it get rectified. I think I also may have worn O2 sensors not sure if this is contributing, it's seems only injector 4 is suffering.
A little puzzled, If you didn't have the problem before doing all the work and now it comes up, how was it determined to be an injector problem ?
We could throw out all kinds of things to do , but best if we start from the beginning.
If all the work was done carefully and correctly, you might be looking at a defective injector..That would require some addl work and don't want to give you addl work if not necessary.
There are a few things you can do until you find a diagram.
The injector should have constant power (12 volts) to it when the key is on, does it?
When the engine is cranking or running the PCM should be providing a blinking ground to it , is it?
Which ever one is missing will determine where you go next.
