01 tiburon starter problem
Drove home from work one day. I got back in the car and tried to start it and nothing. All lights, radio and everything else works. replaced the starter, relay and ignition switch still nothing. I cut the wire from the solenoid and touched it to the positive side of the battery and the starter engaged and cranked the car so I know the starter is good. Could it be the neutral safety switch? I am at a loss so any help would be greatly appreciated. |
RE: 01 tiburon starter problem
Yes, it could be. Is it an automatic or manual? If it's a manual, it may also be the switch on the clutch pedal.
Yes, it is a manual. Is the switch on the tranny or is it on the shifter?
CHECK CLUTCH PEDAL (M/T)
Check that pedal height, pedal freeplay and clutch pedal clevis pin play are correct. (Refer to clutch group) http://www.hmaservice.com/data/Passe...G/eba9020d.gif CHECK STARTER RELAY Remove the starter relay and check continuity between the terminals. If the continuity is not as specified, replace the relay. http://www.hmaservice.com/data/Passe...G/eba9020f.gif CHECK IGNITION LOCK SWITCH Remove the ignition lock switch and check continuity between the terminals. If the continuity is not as specified, replace the switch. http://www.hmaservice.com/data/Passe...G/eba9020g.gif |
Hi, I just bought an 01 tib used and the first thing that went is the crank sensor.Which is a timing deal.The sensor was about 100 $ and it fixed the intermittent starting problem. You need to hook it up to a diagnostic to see if that is it.
| All times are GMT -5. The time now is 07:03 AM. |
