-   -   2000 Tiburon will not start (https://www.hyundaiforum.com/forum/hyundai-tiburon-23/2000-tiburon-will-not-start-11481/)
dgaringer Sep 19, 2011 09:14 AM
2000 Tiburon will not start. Fuel pump does not run when key is turned on so I replaced the fuel pump, no help. I can't seem to figure out where the relay/fuse is for the fuels pump. Can anyone help point me in the right direction?
dgaringer Sep 19, 2011 10:57 AM
I checked both fuse boxes, Under the hood and drivers side by the floor. Nothing labelled Fuels pump. The owners manual says to check the labels on the fuse boxes.
NovaResource Sep 19, 2011 11:10 AM
What happened to my post? Hmmm...
Anyway, the fuses and fusible links should be marked on the box lids.
http://www.hmaservice.com/data/Passe...G/E27B311A.gif
dgaringer Sep 19, 2011 11:26 AM
It looks like I need to find the passenger compartment relay box.
sonictib Nov 26, 2011 08:29 AM
i am have the same thing going on to my tib. i have a 2000 Hyundai Tiburon. that will not get gas to engine! i have replaces fuel pump, filter, Crankshaft Position sensor, Throttle Position Sensor and the relay an still no gas? and the relay is on the frie wall up high on the left side if you have big hands its a bitch to get to.
