2003 Tib GT - Something smells in here...
A few weeks ago my car started producing a toxic smell for no apparent reason. I drove it from work to home, about 3-5 minutes tops, and parked it for about 25-30 minutes for lunch. After I got back in the car and started it up, almost immediately I started getting this smell that I had never before had.
At first I thought it was just something in the area around my place, it was so foreign. Nobody who has smelled it thinks it's coolant, so I've ruled that much out, but that's about it. I've driven it as lightly as I can since then, usually only smelling the fumes after 10 minutes of driving or so(usually corresponding with my engine getting up to normal running temp). Over the past couple days, however, it's gotten noticeably worse. The smell doesn't wait anymore, and I can get a strong smell within a minute or two. As of last night, I heard a kind of 'whining' in the engine now to boot, but I can't help but think they are related. I've yet to take it in to be looked yet for monetary reasons, so now I'm hitting up the internet. The best I can describe the smell is some kind of really sickly sweet, and I at first thought it might be coolant, not having much experience with cars in general. I've had 3 people since then who know much more than me say it doesn't smell like any coolant they've smelled, and it seems more electrical or plastic in nature. No smoke that we can see(although my friend did claim to see a little smoke of some sort coming from under the right front wheelwell after the first time we experienced it). We're pretty sure it's confined to the passenger side of the engine, near the back corner area. That's about all I got here, any help would be very much appreciated! Also of note, the car was in a mild accident in January of 2007, and while it's run fine since then, there was some slight shifting of stuff under the hood so I don't know how much this would affect the little things. Thanks! |
RE: 2003 Tib GT - Something smells in here...
At first I thought it was just something in the area around my place, it was so foreign. Nobody who has smelled it thinks it's coolant, so I've ruled that much out, but that's about it. I've driven it as lightly as I can since then, usually only smelling the fumes after 10 minutes of driving or so(usually corresponding with my engine getting up to normal running temp). Over the past couple days, however, it's gotten noticeably worse. The smell doesn't wait anymore, and I can get a strong smell within a minute or two. As of last night, I heard a kind of 'whining' in the engine now to boot, but I can't help but think they are related. |
ORIGINAL: ken99 I'd start by removing radiator cap (with the engine cold) and checking the coolant level in the engine. The sweet smell indicates a coolant leak with the "whining" coming from the water pump running dry. I'm guessing the leak is somewhere near the back of the engine or on the fire wall where it eventually drips onto an exhaust component. The smell gets worse as the exhaust heats up. With little coolant left, the engine is heating things up much quicker. |
so my next question is what kind of coolant do I use? I figure just the green stuff, but do I also have to do some kind of water mix? Actually, unless you live in the far north where it may freeze tonight, I would temporarialy use straight water. The coolant system has a leak that needs to be found and repaired. Pouring anitfreeze back in before the problem is repaired is a waste, and may leave puddles of antifreeze lying around which is toxic to kids and pets attracted by the sweet aroma. Once the car is repaired, I would have the coolant system flushed and filled with the correct antifreeze. does that go straight into the radiator or into the reservoir on the left side? NOW, either get the car to a mechanic or start looking for the leak. I'd first check around the hoses going through the fire wall into the cabin and the water pump, but the engine could be leaking from a number of places. |
