99 tiburon problem
ok i have a 99 tiburon we just replaced the transmission for the second time and now the car has no power any one with an i dea of what could be wrong . no power to get on highway but it runs smooth no missing i have also replaced the cam sensor and plugs and wires the power band is very abnormal and slugish
RE: 99 tiburon problem
are you sure you put the right trans in
may be the trany is bad. I had the same problem with mine and had to change it again 3x's, the dealer game me a bad trany that led to problems with the motor. Nobody is perfect and they could off make a mistake while assambleing it, or maybe you should check it again.:eek:
