adding horses
how many horses will increase if i buy this headres Headers ?
i have the CAI and my exhaust is 2.25" with flowmaster muffler... |
RE: adding horses
i dont know if i have ever seen a dyno sheet for this, but a header, and a high flow or removed cat should make a MUCH bigger impact than your CAI and catback
RE: adding horses
Realistically you are looking at a solid 10- 15 horses. Depending on the bend of your exhaust maybe 20. Remember that you still need to keep some backpressure for optimum performance.
RE: adding horses
20 HP, i like that...i'm gonna buy my rims first for $671 (wheels + tires) then headers from SharkRacing.com ...
RE: adding horses
adding Headers to a tib that already has a CAI and exhaust will maybe give you 5-10 hp...thats about it
RE: adding horses
RE: adding horses
Typically that is true but if he ran a full exhaust system and cut down restrictions by using a high flow cat and ditched the resignator while keeping the bends in the pipe to a minimum he may be able to milk it for all its worth and squeeze out fifteen to twenty.
RE: adding horses
ummm...no ... the cats on the tib are already considered pretty high flow...by putting on an aftermarket high flow cat..you MIGHT get 1-2 hp
