Back Up Camera
I'm looking at hooking a Back up Camera to my 03 Tiburon. What I'm looking for is how to remove the tail light, and what colour are the back up lght wires.
Your help would be gratly appreciated. Thanks |
RE: Back Up Camera
The true tail light or the Dole light?
RE: Back Up Camera
A true tail light
RE: Back Up Camera
The sections to the two lights were together:
REAR COMBINATION LAMP[/align] 1.Disconnect the negative battery terminal.[/align] 2.Remove the luggage trim side cover.[/align] 3.Remove the 3 screws holding the rear combination lamp and disconnect the wire connectors.[/align] http://www.hmaservice.com/data/Passe...G/ktob007i.gif 4.Remove the rear combination lamp assembly.[/align] http://www.hmaservice.com/data/Passe...G/etoc300b.gif 5.Installation is the reverse of removal.[/align] CENTER HIGH MOUNTED STOP LAMP[/align] 1.Disconnect the negative battery terminal.[/align] 2.Remove the rear spoiler after removing 4 nuts. (External spoiler type)[/align] 3.Remove the center high mounted stop lamp assembly.[/align] 4.Installation is the reverse of removal.[/align] |
RE: Back Up Camera
THANK YOU KEN99, I APPRECIATE YOUR TIME. MY QUESTION TO YOU IS WHERE DID YOU GET THE BREAKDOWN DIAGRAM?
Again thanks |
RE: Back Up Camera
