Bank 1/ Sensor 1
Old Mar 20, 2012 | 09:04 PM
thekid22681's Avatar
Default Bank 1/ Sensor 1
I recently purchared a 2005 tiburon gs 2.0 4cyl. for my daughter. After about a week the check engine light came on. She stopped in advanced auto and had them scan for codes and was told that she needed an oxygen sensor. I purchased and installed it for her. After 3 days of driving, the light has come on again. I scanned it again and here is the code:
P0133
Oxygen Sensor Circuit Low Response
Bank 1 / Sensor 1
Any help would be appreciated on what may be causing this
Old Mar 21, 2012 | 09:05 AM
Which O2 sensor did you replace? There are 2. One before the cat and one after the cat. On an inline 4-cylinder engine, there is only one bank. Sensor 1 is the sensor between the cylinder head the and cat. Sensor 2 is the sensor after that cat.
Old Mar 21, 2012 | 04:49 PM
I replaced the one before the cat right off of the exhaust manifold.
Old Mar 21, 2012 | 05:30 PM
Did you use a Hyundai OEM sensor or an aftermarket brand?
Old Mar 21, 2012 | 06:01 PM
It was a Bosch premium aftermarket from Advanced Auto.
Could of purchased the Hyundai OEM for the same price, but the dealer had to order it.
Old Mar 22, 2012 | 07:51 AM
Well, I've heard of people having problem with non-OEM O2 sensors.
Old Mar 28, 2012 | 04:08 PM
BluShark04's Avatar
Thumbs up Been There
Hi,
I just went thru the same problem on my 2004 Tiburon, same engine and same parts ... bought a Bosch O2 Sensor and after replacing it had the same error P0133 ... then bought a Denso that was more expensive, same error ... finally took it to the dealership and they said it was because I did not use an OEM o2 sensor (Delphi) so I had the dealership replace it to the tune of 291.00 with labor. Drove it home and got the same error ... after 3 weeks of back and forth with the dealership (they tried everything from bad negative battery terminal to wiring harness) they FINALLY figured out it was the exhaust manifold/catalytic converter to the tune of 800.00, and that was the problem. Have them check your exhaust manifold for leaks. Hopefully this will save your the headaches I went through.
Peace.
BluShark04
star54
Mar 1, 2015 08:26 AM
racing1219
Aug 29, 2014 06:56 AM
frogs101
Oct 27, 2007 08:01 PM
instructor
Off Topic
Jun 13, 2005 02:27 PM
