Bank 2 Sensor 1 on 2005 tiberon
Could someone tell me where this sensor is located on my 2005 Tiburon SE?
I understand there are 4 sensors 2 in front and 2 in rear. I heard this is in the rear. Are they both the same part number etc..
I can't seem to find a service manual on 2005 tiberons.
Can you use a regular OHM meter to see which one of the two isn't working?
Thank you for any help
First, it's Tiburon, not Tiberon.
Second, you didn't tell us what engine. I'm going to assume it's a V6.
Bank 1 is always the side of the engine with cylinder #1. Bank 2 is always the side of the engine with cylinder #2. This only matters on the V6, not on the inline 4 cyl. Bank 1 is the bank of cylinders on the firewall side. Bank 2 is the bank of cylinders on the radiator side.
Sensor 1 is the O2 sensor before the cat. Sensor 2 is the O2 sensor after the cat.
So the one you want is the sensor before the cat on the radiator side of the engine.
Before you go wasting TIME AND $$$ for some reason,,,, tell me why you think you need Ox sensor ......
I know something you might not, but you need to tell me what leads you to think you need Ox sensor..
I want the P-xxxx code recovered... very well you may not need an Ox sensor.. but I need to know the code first.
You may wonder why... I am a Gold Level Hyundai Tech, I can guide you in the right direction,,
As Buddy over at Sturm says -- "Help us help you"
I will need to go back to get the P-xxx code, I will go next week, they just told me it was B2S1 when they hooked it up. I appreciate your help!!
I have a 2003 hyundai tiburon gt v6. I have an engine code p1166 and p1167 saying that Bank 2 sensor 1 and Bank 1 sensor 1 is bad. What's the chances of both of these going bad? Also could it be something else causing the code? Thanks!
