-   -   Bank 2 Sensor 1 on 2005 tiberon (https://www.hyundaiforum.com/forum/hyundai-tiburon-23/bank-2-sensor-1-2005-tiberon-10192/)
star54 Jan 27, 2011 07:05 PM
Could someone tell me where this sensor is located on my 2005 Tiburon SE?
I understand there are 4 sensors 2 in front and 2 in rear. I heard this is in the rear. Are they both the same part number etc..
I can't seem to find a service manual on 2005 tiberons.
Can you use a regular OHM meter to see which one of the two isn't working?
Thank you for any help
NovaResource Jan 28, 2011 07:37 AM
First, it's Tiburon, not Tiberon.
Second, you didn't tell us what engine. I'm going to assume it's a V6.
Bank 1 is always the side of the engine with cylinder #1. Bank 2 is always the side of the engine with cylinder #2. This only matters on the V6, not on the inline 4 cyl. Bank 1 is the bank of cylinders on the firewall side. Bank 2 is the bank of cylinders on the radiator side.
Sensor 1 is the O2 sensor before the cat. Sensor 2 is the O2 sensor after the cat.
http://www.hmaservice.com/files/331/.../03360121D.gif
So the one you want is the sensor before the cat on the radiator side of the engine.
star54 Jan 28, 2011 07:58 AM
Thank you
Thank you so much for giving me information. Also thanx for the typo correction
star54 Jan 28, 2011 08:20 AM
Is it difficult to replace? I assume you would not need to purchase universal on something like this, right?
sbr711 Jan 28, 2011 07:56 PM
Before you go wasting TIME AND $$$ for some reason,,,, tell me why you think you need Ox sensor ......
I know something you might not, but you need to tell me what leads you to think you need Ox sensor..
star54 Jan 30, 2011 08:23 AM
My check engine light came on, advance auto hooked up the diagnostic tool..and the guy said it was the bank2 sensor 1. Why? anything is helpful. Are they hard to replace?
sbr711 Feb 1, 2011 10:11 PM
B2S1 has no value to me at this time...
I want the P-xxxx code recovered... very well you may not need an Ox sensor.. but I need to know the code first.
You may wonder why... I am a Gold Level Hyundai Tech, I can guide you in the right direction,,
As Buddy over at Sturm says -- "Help us help you" :)
star54 Feb 5, 2011 06:56 PM
I will need to go back to get the P-xxx code, I will go next week, they just told me it was B2S1 when they hooked it up. I appreciate your help!!
star54 Feb 6, 2011 08:26 AM
sbr711
code is P1154
Thx for the concern
rbark94 Feb 25, 2015 12:09 PM
I have a 2003 hyundai tiburon gt v6. I have an engine code p1166 and p1167 saying that Bank 2 sensor 1 and Bank 1 sensor 1 is bad. What's the chances of both of these going bad? Also could it be something else causing the code? Thanks!
