Clutch Problem
Hello
I recently replaced my clutch and now i only have like a 3" swing to my clutch pedal. i havent tryed to start it or move it as of now. Ive had the transmission out about 4 times trying to find out whats wrong and everything seems to be ok. if anyone has experienced this before please help me. |
RE: Clutch Problem
has anyone tried adjusting the clutch pedal buddy im sure there is a rod near the pedal which is adjustable.:D
RE: Clutch Problem
no there is nothing on the pedal that is adjustable b/c i thought the same thing.
RE: Clutch Problem
in that case have you tried bleeding the system?
RE: Clutch Problem
yup completely cleaned the system, new fluid and bleed the system.
RE: Clutch Problem
ok so can you engage any gears without stalling or any crunching?
RE: Clutch Problem
at that time no i couldnt. but i found out why i had the short swing was b/c the slave cyl. was bottoming out. but it still wasnt disengaging al lthe way. no i needed the car to drive home b/c my college year ended so i mod. the release lever so it did disengage but im going to have to find out why it didnt want to disengage before.
RE: Clutch Problem
this might sound daft but have you got the correct clutch kit installed because if you can move the slave to the end of its stroke then it must be a mechanical fault like either the wrong release bearing or pressure plate?
RE: Clutch Problem
yeah we thought the same thing but we measured both sets and they are within .001 of each other. not enough to make a difference.
RE: Clutch Problem
is it the pull type clutch as in the 1.8/2.0/2.7 or is it the push type in the 1.6?
| All times are GMT -5. The time now is 07:12 AM. |
