Door lock relay position
Old Nov 15, 2007 | 12:17 PM
mikibark's Avatar
Default Door lock relay position
Hi guys,
have you any idea where door lock relay can be placed in Hyundai Tiburon gen3? (I checked engine and passenger fuse box but no lock/unlock relay even on the other side of BCM).
Thank you for your help!
Miki
Old Nov 15, 2007 | 12:53 PM
Default RE: Door lock relay position
First, 2003-07 GK Tiburons are the second generation (gen2). There is no third generation yet. All 1996-2002 RD Tiburons are the first generation.
Second, there is no relay for the door locks. They are controled by the BCM.
Old Nov 17, 2007 | 06:15 AM
mikibark's Avatar
Thank you once again for your help - today I checked the actuator placed in the door - will post some pictures on Monday - and I found out that when I try to lock car by remote the actuator goes in the same direction as when I try to unlock it and therefore doesn't lock the door - can it be just damage in actuator or the signal send by BCM? thanks
chrismgan
Aug 31, 2019 11:51 PM
earlybird
Mar 20, 2011 04:49 PM
wselers
Feb 27, 2011 03:42 PM
madseal7
Nov 13, 2005 12:59 PM
