-   -   Door lock relay position (https://www.hyundaiforum.com/forum/hyundai-tiburon-23/door-lock-relay-position-3363/)
mikibark Nov 15, 2007 12:17 PM
Hi guys,
have you any idea where door lock relay can be placed in Hyundai Tiburon gen3? (I checked engine and passenger fuse box but no lock/unlock relay even on the other side of BCM).
Thank you for your help!
Miki
NovaResource Nov 15, 2007 12:53 PM
RE: Door lock relay position
First, 2003-07 GK Tiburons are the second generation (gen2). There is no third generation yet. All 1996-2002 RD Tiburons are the first generation.
Second, there is no relay for the door locks. They are controled by the BCM.
mikibark Nov 17, 2007 06:15 AM
Thank you once again for your help - today I checked the actuator placed in the door - will post some pictures on Monday - and I found out that when I try to lock car by remote the actuator goes in the same direction as when I try to unlock it and therefore doesn't lock the door - can it be just damage in actuator or the signal send by BCM? thanks
