Electrical Problem
My daughter has a 03 Tiburon. She purchased a radio faceplate to replace the Infinity one that was not showing digital channels. It was installed by a friend of hers. After it was done some of the dash lights and lights for the console do not work. Also her right rear light is out. Anything I can look at? Fuses?
Thanks Mike Allegretti |
If they did not use the correct wiring adapter i would check the stereo wiring its possable they hooked the ground up to the high beam becuase when high beams are off its a ground bukt then hot when high beams are hit so i would check this and look at the fuses may be blown
| All times are GMT -5. The time now is 02:43 AM. |
