front wheel bearing replacement 2000 tiburon
can someone tell me how to remove the front wheel hub bearing on a 2000 tiburon. i have completely removed the hub assembly. can t get the spindle out. Anyone have experience with this issue? Thanks for any help..
you have to remove the snap ring,them press the hub out,them press the bearing out,to install put the snap ring back in,press the bearing in,them press the hub in.
