Heater Only Blowing on LOW setting
So I know that Blowing on High setting is a normal problem in cars but I have a 2003 Hyundai Tiburon gt thats heat is only blowing on the Low setting, It still gets hot and everything but Im looking to fix it so any help in whats wrong would be greatly appriciated. Thanks all.
Even if you dont know forsure, even just some suggestions or guesses would be nice!
Thanks! |
First, you posted your question at 1:41 Am Eastern time. I doubt you’ll get many replies that early in the morning. Have patience.
Second, you need to describe your problem better. Do you mean the fan is not blowing except on low speed? |
I have patients ........ I wasnt expecting to many replys i saw 11 people looked at it and I just wanted to let people know Im open to ANY suggestions .. even if is just a guess.
and Yes the fan only blows on low speed setting, medium or high it just stops. It could be the switch but i am not sure seeing if any on had the same problem or knows of any other suggestions. |
It could be the switch or it could be the fan speed resistor.
ok thanks!
