Horn
Does anyone have the schema for the horn on a 03 Tiburon? It was disconnected and trying to see if I can reconnect.
Thanks |
RE: Horn
There are 3 horns in the GK, Tiburon. 2 are the actual "horn" when you press the center of the steering wheel. One is for the alarm. The 2 for the actual horn are located just behind the grille. The alarm horn is located between the battery and the driver side fender.
