-   -   How to Remove Stock Radio in 2003 Tiburon (https://www.hyundaiforum.com/forum/hyundai-tiburon-23/how-remove-stock-radio-2003-tiburon-5219/)
Harry454 Dec 2, 2008 05:00 PM
Hey can anyone tell me how to remove the stock radio in 2003 tiburon gt without infinity system, or post a link to a guide thanks
NovaResource Dec 2, 2008 05:27 PM
RE: How to Remove Stock Radio in 2003 Tiburon
It's very simple, Just open the ashtray then put your fingers under the center bezel where the ashtray is and pull it out. Once the center bezel if out, just remove 4 screws and the head unit slides out. Very simple.
https://www.hyundaiforum.com/m_9819/tm.htm
https://www.hyundaiforum.com/m_10712/tm.htm
Harry454 Dec 2, 2008 06:00 PM
and regards to wiring I bought the wiring Harness, so I would just connect the wires from deck to harness then connect harness to stock harness correct? also I got a indash dvd deck so like would I need to install the Ebake switch detector, if I dont then the unit will play movies while driving right instead of only when parked.
NovaResource Dec 3, 2008 07:18 AM
Yes, that's the best way to connect an aftermarket head unit. That way you don't chop up the factory harness.
Harry454 Dec 3, 2008 08:28 AM
regards to ebrake how would i go about connecting it? Is the wire already in the harness
NovaResource Dec 3, 2008 08:34 AM
No, it's not. You'll have to tap the wire in the console where the e-brake handle is.
Harry454 Dec 3, 2008 10:30 AM
how would I go about accessing the ebrake console and where exactly do i connect the wire? Any link to a guide or some? Thanks a lot
NovaResource Dec 3, 2008 11:24 AM
The wire for the parking brake switch is attached to the parking brake lever.
http://www.hmaservice.com/data/Passe...G/ejoe901a.gif
To access the switch you need to remove the console:
CONSOLE REMOVAL AND INSTALLATION
1. Remove the front seat.
2. Remove the console upper cover.
http://www.hmaservice.com/data/Passe...G/ksob130b.gif
3. Remove the console front mounting screws.
http://www.hmaservice.com/data/Passe...G/ksob130a.gif
4. Remove the floor console.
http://www.hmaservice.com/data/Passe...G/ksob130d.gif
5. Installation is the reverse of removal.
