keeps stalling, not CPS, or coil pack... any ideas??
My 98 Tib, will drive for a short distance, then stall, and won't start for about 20 min. It does turn over, but won't start. When it's not working, there is no spark. It's not the Cam Position Sensor or the Coil Pack. It has newer plugs, and wires also. Anybody have any ideas of what it could be???? I have no clue:)
Thanx, later |
RE: keeps stalling, not CPS, or coil pack... any ideas??
same prob with my 98 tiburon... please help us. |
It ended up being a the Crank Shaft Position Sensor
http://cgi.ebay.ca/96-01-HYUNDAI-ELA...QQcmdZViewItem Here is a link for one. It's $69 US, it was about double that at the dealership. Thats with shipping delivered to your door, from Korea, in like 2-3 days. Hope that helps you. They are also very easy to change, only a 5-10 minute job. It's one bolt, and one electrical connector. It's located on the right side of the engine block, just beside the cat. |
did it set a check engine light code when it malfunctioned?
Well the thing with mine, is that I have all after market exhaust, and my engine light is always on. Haven't figured out a solution for that problem. I would imagine that it would send a code though. Umm, I don't know what else to tell you, other then to maybe take it to the dealer, or someone who has a scanner, if you don't want to take the chance on buying that sensor.
Later, Stacey |
check ur fuel pressure or maf mass air flow have tendences to be ****
| All times are GMT -5. The time now is 02:54 AM. |
