My Tiburon Won't even fire
Ok
I got a 1997 Hyundai Tiburon. It over heated and hasn't ran ever since. It turns over fine but won't fire .... I need help with this |
Overheating can sometimes cause the head gasket to fail which then allows for a number of possible problems
One is coolant into motor oil or the other way around Another is loss of compression which would not be helpful in starting an engine Or it could be a bad crank or cam sensors Even something else that I haven't heard about It should be back to basics and start by checking to see if you have spark, fuel And let that lead you to where look Good luck to you |
