plastic engine panel removal
Old Nov 1, 2008 | 11:57 AM
TONTOE2004's Avatar
Default plastic engine panel removal
Can anyone tell me how to remove the plastic engine panal to get to the spark plugs on a 2004 tiburon gt, i have taken out two bolts and don't want to force anything that might break. Thanks
Old Nov 1, 2008 | 01:51 PM
Default RE: plastic engine panel removal
You need to remove the Hyundai (H) emblem next to the oil fill cap because there is a bolt under it. You also need to remove the 2 middle silver ribs as there are bolts under them as well.
If you are replacing the spark plugs, I hope you realize the upper intake manifold needs to be removed to access the rear 3 plugs. Here's how to do thet:
http://www.newtiburon.com/forums/showthread.php?t=1760
Old Nov 1, 2008 | 02:03 PM
TONTOE2004's Avatar
Thank You very much, you were a huge help!!!
steelsun
Mar 23, 2015 07:05 AM
uncle_stepa
Mar 6, 2012 01:11 PM
mrmc357
Mar 30, 2011 08:21 AM
bangrapp
Nov 11, 2010 09:44 AM
gunwaleman
Jul 17, 2009 07:23 PM
