Replacing dashboard dimmer switch
Old 04-11-2010, 10:03 PM
marcpro's Avatar
Default Replacing dashboard dimmer switch
My dashboards lights are very dim, and the dimmer switch has no effect.
Is there an easy way to get at this switch to remove and replace it?
Thanks.
Old 04-12-2010, 06:06 PM
pdirico's Avatar
Default dimmer Switch
Just like your typical dimmer switch at home inside there is a variable resistor. the one main reason why your dash lights are low is because your resistor is pooched. The resistor controls how much voltage goes through...lower the resistance brighter the bulb higher resistance lower the bulb. Yes it is possible to get it fixed....just replace the switch
Old 04-13-2010, 08:59 AM
marcpro's Avatar
Thanks Pdirico.
Is the switch easy access under the dash?
Or do I have to remove parts of the dashboard?
Old 04-13-2010, 09:34 AM
What year ?
Old 04-14-2010, 09:33 AM
marcpro's Avatar
It's a 2003, sorry, should have said that earlier.
I need to change the dimmer switch, and also the bulbs from the center consode (where the AC and fan ***** are) because that's all dark.
Old 04-14-2010, 11:21 AM
If I would have known yesterday, I could have looked at the fellas' car with the fried BCM...
I went to HMA site, in the tech login, the pic of the dash-component looks like it (rheostat) should just pop out of dash..
Old 09-17-2010, 11:47 AM
marcpro's Avatar
I got the dimmer switch out.
sbr711, can you get a schematic diagram from the HMA site?
I'ld like to test it outside the car before I plunk $90 for a new switch. I have tools, I can rig up something to test it, I just need to know the pinout.
There is voltage to the harness, I checked.
Old 09-18-2010, 01:10 AM
marcpro's Avatar
I'll reply to my own thread with what I've got so far:
1- I purchased a new rheostat online from Hyundai Parts Wholesale, http://www.partswebsite.com/hyundaipartswholesale/
Part number is 949502C000, about $46 with shipping. Price was $86 at dealer here in Calgary, Canada.
2- I found the schematic, at this link:
http://hmaservice.com/data/Passenger...G/e2ge345a.svg
It's all starting to make sense now. I'll update when I receive the part and hopefully fix this problem.
Cheers.
Old 11-21-2017, 11:15 PM
Beverly Jeffries's Avatar
Was it difficult to find and replace the dimmer switch? I have a 2002 Elantra GT and the dash lights are really dim... Thanks
Old 11-22-2017, 06:50 AM
avisitor's Avatar
This thread is a little more than 7 years old
The members might have forgotten about this little adventure
spoolenturbo
06-03-2022 01:25 PM
ddzc
04-11-2009 08:21 PM
Cable Guy
03-17-2008 12:09 PM
johann78
03-13-2008 03:03 AM
rwesten
01-15-2008 07:40 PM
Quick Reply: Replacing dashboard dimmer switch
