rod bearing orientation
how do I line up the rod bearings when they have no oil hole?
I have a question
I own 2008 Hyundai tiburon .gt, I'm getting a scrapping squeaky sound coming from my drivers front wheel, I assumed it was brake pads needing changed however that's not the problem... how .or what can I do to know if it's the bearings..... help |
Originally Posted by Willie McNair
(Post 48700)
I looked at some bearings on google. As I thought you should have a oil hole for the connecting rod and no hole for the bearing cap. Otherwise I would double check you don't have a bad set as the piston end needs oiled. |
Originally Posted by malcolm.gatewood
(Post 49635)
I have a question
I own 2008 Hyundai tiburon .gt, I'm getting a scrapping squeaky sound coming from my drivers front wheel, I assumed it was brake pads needing changed however that's not the problem... how .or what can I do to know if it's the bearings..... help Try running with the brake pads on and listen put a screwdriver on the bearing housing. Usually you can hear a bearing. |
| All times are GMT -5. The time now is 09:49 AM. |
