Service manual for slushbox replacement
Hi,
Looks like my daughter's Tib will need the auto replaced soon. Wondering if there's a decent manual or maybe a photo tutorial online describing what's involved. Fluid is light brown, smells a little burnt, and there are scraping noises coming from the trans. She reports loss of power going uphill. About 80k on the clock. This doesn't sound like a situation that a fluid and filter will resolve, does it? Thanks . . . |
RE: Service manual for slushbox replacement
Wondering if there's a decent manual or maybe a photo tutorial online describing what's involved. 2003 > G 2.7 V6 DOHC > Automatic Transaxle System REMOVAL1.Remove the engine cover.[/align] http://www.hmaservice.com/data/Passe...G/kmob001a.gif 2.Remove the battery terminal.[/align] http://www.hmaservice.com/data/Passe...G/kmob002a.gif 3.Remove the air duct.[/align] http://www.hmaservice.com/data/Passe...G/kmob003a.gif 4.Remove the battery tray.[/align] http://www.hmaservice.com/data/Passe...G/kmob004a.gif 5.Remove the air cleaner.[/align] (1)Upper[/align] http://www.hmaservice.com/data/Passe...G/kmob005a.gif (2)Lower[/align] http://www.hmaservice.com/data/Passe...G/kmob006a.gif 6.After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.[/align] http://www.hmaservice.com/data/Passe...G/kmob008a.gif 7.Remove the speedometer sensor connector.[/align] 8.Remove the transaxle range switch.[/align] http://www.hmaservice.com/data/Passe...G/ekac009b.gif 9.Remove the oil cooler hose.[/align] http://www.hmaservice.com/data/Passe...G/ekac009c.gif 10.Remove the clip (transaxle side) of the shift cable.[/align] http://www.hmaservice.com/data/Passe...G/kmob014a.gif 11.Separate the steering column shaft joint.[/align] http://www.hmaservice.com/data/Passe...G/kmob016a.gif 12.Separate the power steering oil pump hose.[/align] http://www.hmaservice.com/data/Passe...G/kmob017a.gifhttp://www.hmaservice.com/viewer/img/note_icon.gifBe careful not to leak after separating.[/align] 13.Separate the hose after removing the clip of the power steering return hose.[/align] http://www.hmaservice.com/data/Passe...G/kmob018a.gif 14.Remove the upper connecting transaxle bolt.[/align] http://www.hmaservice.com/data/Passe...G/kmob020a.gif 15.Separate the start motor.[/align] http://www.hmaservice.com/data/Passe...G/kmob021a.gif 16.Install the engine support fixture.[/align] 17.After removing the tire, remove the caliper.[/align] http://www.hmaservice.com/data/Passe...G/kmob024a.gif 18.Remove the transaxle side cover.[/align] http://www.hmaservice.com/data/Passe...G/kmob023a.gif 19.Remove the transaxle under cover.[/align] http://www.hmaservice.com/data/Passe...G/kmob025a.gif 20.Separate the tie rod end.[/align] http://www.hmaservice.com/data/Passe...G/kpka032a.gif 21.Remove the wheel speed sensor and the knuckle mounting bolt.[/align] http://www.hmaservice.com/data/Passe...G/kmob026a.gif 22.Drain the oil.[/align] |
