Speedometer not working
2007 hyundai tiburon gt speedometer not working after I replaced stereo anyone knows how to fix it what fuse is it and where is it located?
Simpler to check all the fuses with a test light.
Clip to ground (make sure it is a good ground). Probe the two test points on top of the fuse One test point above each leg of fuse If both side light up then good fuse If only one then fuse is blown If no light then no power to fuse |
