tiburon rear drivers side tire is not moving!! help!
So last night I parked my tiburon, turned it off,put it in 1st, and pull the hand brake up..
and... about 3 inchs of snow later..and 12 hours later..
this morning i got in, put it in neutral, turned it on,put the hand break down, took off and heard my dad scream!! what for? my rear left tire was not spinning but the rest of the 3 were..
so i left it as it was.. left the hand break down, but put it in 1st and took a different car to school, i just got back and it is still doing the same exact thing!! what is the problem here?
someone please help! it is still pretty cold up here.. idk if that has to do with anything or not..
also two days ago the ABS light in my dashboard has been staying on.. even after i start my car, and i am driving it..
RE: tiburon rear drivers side tire is not moving!! help!
This is very common. The Tiburon is known to have the parking brake freeze-up in very cold/damp weather. You have to let it thaw out or get under there and heat the parking brake cable to release.
I just kept reversing and driving and eventually, after like 10-15 times of doing that, it loosened up and it seems fine now.. so right now I have it in gear and left the brake down.. Next time i get my oil changed, Ill have the guys lubricate the cables, but is WD 40 the best thing to use? or is there something better?
and is it safe to leave the car just in gear durring the winter months?
If you have manual, then just leave it in first gear. If you have auto, then just leave it park. I NEVER use my parking brake in winter unless there's a compelling reason like a hill.
ORIGINAL: jsinton
Just because there is a problem with the cable doesn't mean you shouldn't use it. It means the cable should be fixedcorrectly and then used properly.
ORIGINAL: tiBuronGt
Oh, okay, thanks man! i will definitely have the next person that changes my oil, lubricate the cables.. How often should i get this done? every time i change the oil? and double lubrication during the winter months?
