Tiburon wont start
I have a 1998 Tiburon. It has a 2001 engine and transmission. It has also been converted from automatic to manual. The starter is not engaging. Everything else seems to be fine. when I turn the key, all the electrical comes on, just no starter. Nothing from it. It hasnt given me any problems until now.
are you getting 12~14 volt at the starter, you might want to start there, then work you way back. if you are then pull it and take it to autozone or some place like that you they can bench tested. if you not getting any volts then you need to check the nautral safety switches depending on the transmission type... you luck
| All times are GMT -5. The time now is 05:40 AM. |
