timing 2000 tiburon --2.0 cid
Need help on timing--timing belt broke ! Thanks in advance for your help
donk74035@yahoo.com |
Was it running when the belt broke? If it was you'll need to replace more then just the belt. It's an interference motor so the valves probably hit the pistons. Better pull the head first and check for bent valves.
