Turbos
Which turbo you think is better for a 2001 Tiburon (automatic):
1- Hyundai I4 Beta Extreme Turbo Kit 2- Hyundai I4 Beta Basic Turbo Kit 3- Hyundai Performance ========== I already fixed the links so now they should work properly.... |
RE: Turbos
how much are each of these kits and what is included IE: supporting mods like fuel injectors and fuel controll and also some type of voltage clamp for the MAF so you don't throw codes let me know I might be able to help you out
Tony |
RE: Turbos
1. Hyundai I4 Beta Extreme Turbo Kit $3,100.00
T3/T4E Turbo (50 trim) (Internal Gated) 304L Stainless Steel Log Style Manifold Down pipe Intake Air filter SS Oil feed line and Oil return line and fittings Charge pipes HKS Style SSQV BOV Greddy or HKS Turbo Timer Autometer Boost Gauge Apexi SAFC 2 or Perfect Power SMT-6 (Select Option Below) 340cc Injectors Walbro 255lph Fuel Pump Front Mount Intercooler (Deminsions: 31x6.5x3) Silicone Couplers 2. Hyundai I4 Beta Basic Turbo Kit $2,200.00 T3 Super 60 Turbo( Internal Gated ) 304L Stainless Steel Log Style Manifold Down pipe Intake Air filter SS Oil feed line and Oil return line and fittings Charge pipes HKS Style SSQV BOV Greddy or HKS Turbo Timer Autometer Boost Gauge Vortech FMU Silicone Couplers 3. Turbocharger with Intercooler Kit $2,950.00 this kit doesn't specify what are the components but here is a pic Pic 1Pic 2Pic 3 |
RE: Turbos
Personally I think all these turbos are good ,If you havea built motor, Because cause all of the turbos listed here are fairly decent sized turbos they arent really working to the full or even half the potential that they should be, these tubos are generaly used for running moderate boost IE 15psi or more and on a stock bottom end you can genarally run 7 to 10 psi max without getting detonation, and these turbos are also have more turbo lag than say a DSM 14b or T25 would have. So I say build your own kit with a DSM turbo and when the time comes to rebuild your motor because you fried your rings and the boost is shooting out your dipstik, then do the internals and upgade your turbo to something bigger,
RE: Turbos
OK, thanks dude, i'm gonna start looking for dsm turbos...
i found this dsm turbo... Star Stage 2 Kit but it doesn't say to what car it can fit...and i don't know if it will fit in my car (2001 Tib) |
RE: Turbos
look on dsm trader for a 14b or t25 if you are looking at building your own kit.
Just a few questions before you start building your kit, just wanting to know you are up to all the fabricating included in putting this kit together or if you would rather buy a kit, because it does take some bit of knowledge to get it all workng properly, are their any performance shops inyour area? |
RE: Turbos
i rather buy a kit because i don't really know too much about performance...about the performance shop, yes there is one near me...
RE: Turbos
thats cool . have you decided on a kit yet
RE: Turbos
I have 2001 tib (man) and i wanted to turbo it. so if you turbo yours i would much aprreicate it if you could give me any feed back on how it does, and you recomend it. I also wanted to know if there is any other prep work that has to be done before i buy i kit? right know i have AEM cold air intake and the 1.8L cam swap. I like the SOUND A LOT and the powre gain is alright but still not enough. any sug?
RE: Turbos
Scott, Hi iI have already done 1 turbo kit for a friend with a 98 Tib 2.0 and also have another buddy who has turboed his Elantra, and both work great but the one Idid runs a little better, just because it was put together a little nicer. Are you planning on building a kit or buying a whole kit let me know so I can further assist you.
| All times are GMT -5. The time now is 05:42 AM. |
